This page provides information about the Combine Float node in V-Ray for Cinema 4D.
HideElements
cssselector#tocVertical, #tocHorizontal
width57%
 This node allows you to multiply a texture with a float value.
width5%
width38%
width57%
Value – The value to multiply the texture with.
Texture – An input slot to connect the texture to.
Mix StrengthA multiplier for the connected texture - blends between the value and the texture.
Texture ClampWhen enabled, the output is clamped to 1 from above (always clamped to 0 from below).
Result Multiplier – Specifies a multiplier for the end result.
width5%
width38%
