This page covers the basics of using XGen with V-Ray for Maya, including a step-by-step guide to controlling XGen Attributes through texture maps.
UI Button | ||||||||||
Prerequisites
Section | ||||||||||||||||
Section | |||||||||||||||||||||
Basics
The following images show how instanced primitives look when the base mesh has a low versus a high subdivision. Note how XGen clumps primitives more to the center of each face. This is the same behavior for all kinds of primitives.
Base meshes onto which XGen populates primitives, should use Maya's subdivision settings, as V-Ray's own subdivision settings will not work with them.
Materials and V-Ray Object Properties may be assigned to descriptions and all primitives for that description will share them; they can also be assigned on a per-patches basis for fine-grained control over primitives on different patches. This means two patches in the same description can use different materials and have separate V-Ray Object Properties.
For example, if you have a description with four patches in it, you can assign a master material to the description and give a specific material to one of the patches, such as in the example shown below:
UI Text Box | ||
Assign the description material to the transform node, not to the shape node. Such assignments are hierarchical, meaning they affect the selected node and all its children: the patches are children of the description transform, not the description shape. |
The following section describes two ways of controlling XGen attributes: through expressions or through texture maps.
Part I: Through Expressions
Part II: Through Texture Maps
Section | ||||||||||||||||||||||
Editing the Expression
If we edit the expression of the Length attribute through the Sigma button from this:
Code Block language php $a=map('${DESC}/paintmaps/length');#3dpaint,200.0 $a
to this, we can invert the result of the map:
Code Block language php $a=map('${DESC}/paintmaps/length');#3dpaint,200.0 $a = 1.0 - $a; $a
- Add a dome light with an HDRI dome tex to the scene, apply V-Ray Materials, and render. We should see something like this:
