Responsivegridmacro
VAlignmentstart
Columns2repeat(2, 1fr)
Columns3width1000px
Columns1repeat(3, 1fr)
Columns1width1540px
Columnsrepeat(4, 1fr)
Columns2width1290px
CSS Stylesheet
.UIImage {
max-width:650px;
margin-left:auto;
margin-right:auto;
This page offers information about the Lights tab in Chaos Vantage.
The Lights tab offers a list of all lights in the scene and their properties. This includes lights imported with a .vrscene file.
UI Text Box
typeinfo
You can use the right mouse button click to reset the parameters numeric values to defaults.
UI Text Box
typeinfo
The Lights tab is not available during Live Link connection.
Scene sub-state
width65%
Scene sub-state – A dropdown list of all scene lights sub-states.
Create (Vantage_CCtab_CreateSubState.png) – Creates a new scene lights sub-state.
Update (Vantage_CCtab_UpdateSubState.png) – Updates a scene lights sub-state.
Delete (Vantage_CCtab_DeleteSubState.png) – Deletes a scene lights sub-state. Double-click to delete.
UI Text Box
typeinfo
Note that the default scene sub-state cannot be updated or deleted.
width5%
width30%
Light Lister
The Light lister lists all lights and their properties imported with a .vrscene file.
UI Text Box
typeinfo
Lights that have [G] in front of their name are grouped and share properties. Changing any value will be instanced in all the grouped lights. You can ungroup lights by clicking the checkbox in front of "Grouped with ## other lights"
Expand
titleClick here for UI...
Div
classUIImage
UI Text Box
typeinfo
Lights are automatically grouped/instanced if they share similar properties. This functionality is available if the Display controls for all lights is disabled in the UI section of the Preferences dialogue.
UI path: Edit menu > Preferences > UI > Display controls for all lights
Expand
titleClick here for Preferences UI...
Div
classUIImage
width65%
ButtonButton nameDescription
CompactDisplays only On/Off, color and intensity parameters for lights in the Light lister.
BasicDisplays common parameters for lights in the Light lister.
Advanced Displays all available parameters for lights in the Light lister.
Enable all lightsTurns on all lights in the list.
Disable all lightsTurns off all lights in the list.
Ungroup selected lightsUngroups selected lights in the scene which are part of a light group (have matching and identical properties) and makes them unique.
Image Added
Import lights from fileImports a light(s) from an external supported file and adds it to the Light lister.
Expand all lightsExpands collapsed lights in the list.
Collapse all lightsCollapses all lights in the list.
Search FilterFilters the lights list and shows only those lights that contain the input string. Click on the X button on the right to clear the input string.
ClearClears the filter string.
FilterFilters which types of light (Point, Spot, Directional, Rectangle, Disc, Sphere, IES, Mesh) are listed in the Light lister. Right-click the button to reset the filter. Use Ctr + click to isolate a selection.
Sort
Opens a submenu with options for sorting the lights in the Light lister by the following criteria:
Sort by name – Sorts the objects alphabetically.
Sort by creation
– Sorts the objects by order of creation.
Ascending
– Sorts objects ascending order depending on Sort by name and Sort by creation option.
Descending
– Sorts objects alphabetically in descending order depending on Sort by name and Sort by creation option.
width5%
width30%
Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
classdashboard
Textboxcard
CardTooltipClick to open the V-Ray Sun page.
CardPageLinkSun Light
Sun Light
Click for detailed information about V-Ray Sun and its parameters.
Textboxcard
CardTooltipClick to open the V-Ray Sphere Light page.
CardPageLinkSphere Light
Sphere Light
Click for detailed information about V-Ray Sphere light and its parameters.
Textboxcard
CardTooltipClick to open the V-Ray Rect Light page.
CardPageLinkRect Light
Rect Light
Click for detailed information about V-Ray Rectangle(Plane) light and its parameters.
Textboxcard
CardTooltipClick to open the V-Ray IES Light page.
CardPageLinkIES Light
IES Light
Click for detailed information about V-Ray IES light and its parameters.
Textboxcard
CardTooltipClick to open the Max Point Light page.
CardPageLinkMax Point Light
Max Point Light
Click for detailed information about Point(Omni) light from 3ds Max and its parameters.
Textboxcard
CardTooltipClick to open the Max Spot Light page.
CardPageLinkMax Spot Light
Max Spot Light
Click for detailed information about Spot light from 3ds Max and its parameters.
Textboxcard
CardTooltipClick to open the Max Direct Light page.
CardPageLinkMax Direct Light
Max Direct Light
Click for detailed information about Direct light from 3ds Max and its parameters.
Textboxcard
CardTooltipClick to open the Point Light page.
CardPageLinkPoint Light
Point Light
Click for detailed information about Point(Omni) light and its parameters.
Textboxcard
CardTooltipClick to open the Spot Light page.
CardPageLinkSpot Light
Spot Light
Click for detailed information about Spot light and its parameters.
Textboxcard
CardTooltipClick to open the Direct Light page.
CardPageLinkDirect Light
Direct Light
Click for detailed information about Direct light and its parameters.
