Required Elements
This is a diagram of the most simple possible scene that will render an object. These are the plugins and parameters you will need to create and connect:
Fancy Bullets |
Code
Here's the complete code which constructs the minimal scene in different languages. It uses LightRectangle to get more directional lighting than the dome light would provide:
Tabs Container | ||||||||||||||||||||||||||||||||||||||||||
