The following MDL material files are included when installing V-Ray for Maya. They are located in Local Disk (C:) > Program Files > Chaos Group > V-Ray > Maya 20yy 20xx for x64 > vray > mdl.
width5%
width30%
Aluminum Anodized
width30%
Architectural
width30%
Asphalt
width5%
VRAY_MDL_PATH_MAYA20yy_x64=%PROGRAMFILES%\Chaos Group \V-Ray\Maya 20yy 20xx for x64\mdl;%PROGRAMDATA%\NVIDIA Corporation\mdl;%USERPROFILE%\Documents\mdl
where yy xx is the version of Maya installed.
VRAY_MDL_PATH_MAYA2018_x64=C:\Program Files\Chaos Group \V-Ray\Maya 2018 for x64\mdl;%PROGRAMDATA%\NVIDIA Corporation\mdl;%USERPROFILE%\Documents\mdl
3.  Tell V-Ray where the MDL repository is by appending it to the VRAY_MDL_PATH_MAYA20yyMAYA20xx_x64 environment variable.
VRAY_MDL_PATH_MAYA2018_x64=C:\Program Files\Chaos Group \V-Ray\Maya 2018 for x64\mdl;C:\Program Files\Adobe\Adobe Substance 3D Designer\resources\view3d\iray\alg;X:\MDL
