width100%
Chaos Scatter is a powerful instancing and distribution tool that allows you to easily populate scenes with selected objectsmodels of your choice. This is especially useful for outdoor scenes that need to be filled with greenery, rocks, grass, etc. The Chaos Scatter tool creates instances of specified objects using models on the surfaces and edges of other objects or splines to generate points.
UI Text Box
typewarning
Currently, only Cosmos objects can be scattered on surfaces.
width0%
width0%
UI Expand
expandedtrue
titleUI Path
width49%
||Create menu|| > Scatter
width2%
width49%
||Toolbar|| > Scatter
All Scatter objects are located in the Objects paneltab > Scatter filter tab. All Scatter objects' parameters are accessible in the Details paneltab.
To scatter an object follow these steps:
Click the Scatter (Image Removed) toolbar button or go to the Create menu and select the Scatter option.
Pick a surface to scatter the objects on it. Click Done when ready.
Open the Cosmos Browser from the File menu > Open Cosmos Browser, or open the Cosmos library in the bottom expandable panel by clicking the Cosmos (Image Removed)button.
Pick a Cosmos asset and drag it into the Models field of the Scatter layer. Pick as many assets as you like. You can delete the extra ones with the Remove tool.
  • Set the Density and Max angle to up vector options. If necessary, specify exclusion areas too.
  • Section
    width55%
    width5%
    width40%
    Image Removed
    width55%
    The following parameters are located in the Details right-hand side panel tab and are available upon selection of any Scatter object from the Objects left-hand side paneltab.
    Image Modified
    A field showing the type and name of the selected
    element
    object, allowing you also to rename
    the element
    it. The new name is automatically displayed in the respective
    Object
    Objects tab.
    Image Modified
    Image Removed
    Disables the transformation options for the selected Scatter - position, rotation, and scale. Click Image Added to enable the options for manipulation again.
    Image Added
    Toggles the visibility of the
    element
    Scatter on and off. Invisible objects are indicated by Image Modified.
    Image Added
    Selects the parent element and all of its children.
    Image Added
    Selects the parent
    element
    Image Added
    Selects all children
    elements
    Image Added
    Makes the selected instance unique.
    Image Added
    Selects all instances.
    Image Added
    Saves the current settings as a Scatter preset.
    Layers
    – Adds a new layer.
    – Removes the selected layer.
    Density – – Defines the density of the scattered models in the number of instances per 100 square meters.
    Max angle to up vector –
    Detect collisions –
    Models –
    – Defines the maximum angle of the surface on which the models are scattered. A value of 0 means that the models can only be scattered on horizontal surfaces. A value of 180 means that the models can be scattered on any possible surface angle.
    Detect collisions – Prevents the scattered models from colliding with each other.
    Models – The list of models used in the currently selected Scatter.
    Image Added– Removes a model.
    UI Text Box
    typeinfo
    You can double-click on a layer to change its name.
    Targets
    Image Added
    Allows picking new objects (primitives or splines) to scatter on.
    Image Added
    Removes the specified scatter-on object.
    Exclusion Areas
    Image Added
    Allows picking objects (primitives or splines) which define the exclusion areas.
    Image Added
    Removes the specified object from the list of exclusion areas.
    width5%
    width40%
    See also:
    Thumbnailspagesettings
    ThumbnailOverlayRectangleColour0,0,0
    ThumbnailOverlayRectangleOpacity0.5
    ThumbnailBGImageHeight100px
    ThumbnailOverlayOpacity0
    ThumbnailSubTextSize13px
    ThumbnailTextColourWhite
    ThumbnailTitleTextSize22px
    ThumbnailOverlayRectangleHeight80%
    ThumbnailOverlayRectangleBottomPadding10px
    Responsivegridmacro
    VAlignmentstart
    Columns2repeat(2, 1fr)
    Columns3width1000px
    Columns1repeat(3, 1fr)
    Columns1width1540px
    Columns2width1290px
    Div
    stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
    classdashboard
    Textboxcard
    CardPageLinkScatter Workflows
    Scatter Workflows
