HideElements | ||
Thumbnailspagesettings | ||||||||||||||||||
Responsivegridmacro | ||||||||||||
Utility Textures allow users to perform a variety of helpful functions on texture maps inside a scene (such as compositing textures together and value conversions), as well as provide color corrections option.
A Utility Texture can be replaced with another Utility Texture or any other type of V-Ray texture via the Replace With New Texture (
) button, which activates when you select the texture to be replaced. If the texture is an instance, all copies are changed as well.UI Text Box | ||
In V-Ray 7, the Simple Mix, Mix (Value), Mix (Operator) and Mix (Map) textures are no longer available. They are replaced by the Layered texture. |
Div | |||||||||
Section | |||||||||
Column | |||||||||
Column | width | 20%||||||||
Column | | ||||||||
Column | |||||||||
Thumbnail | ||||||
width | 10% |
width | 20% |
Thumbnail ThumbnailTitleText
Layered ThumbnailBGImage
Layered.png ThumbnailPageLink https://docs.chaos.com/display/VRHINO/
width | 10% |
Layered
width | 10% |
width | 20% |
width | 10% |
Column | ||||||||
width | 10% |
width | 20% |
MultiSub ThumbnailBGImage MultiSubTex_Hero.png ThumbnailPageLink https://docs.chaos.com/display/VRHINO/MultiSub
width | 10% |
width | 20% |
width | 10% |
width | 20% |
Spline Curve Correction ThumbnailBGImage SplineCurve.png ThumbnailPageLink https://docs.chaos.com/display/VRHINO/Spline+Curve+Correction
width | 10% |
width | 20% |
Thumbnail ThumbnailTitleText TriPlanar ThumbnailBGImage TriPlanar.png ThumbnailPageLink https://docs.chaos.com/display/VRHINO/TriPlanar
width | 10% |
