This section contains details about Utility Textures found in V-Ray for Rhino.
Utility Textures allow users to perform a variety of helpful functions on texture maps inside a scene (such as compositing textures together and value conversions), as well as provide color corrections option.
A Utility Texture can be replaced with another Utility Texture or any other type of V-Ray texture via the Replace With New Texture (
) button, which activates when you select the texture to be replaced. If the texture is an instance, all copies are changed as well.In V-Ray 7, the Simple Mix, Mix (Value), Mix (Operator) and Mix (Map) textures are no longer available. They are replaced by the Layered texture.
