width60%
The V-Ray Speckle Texture is a procedural texture that uses two colors or texture maps to produce a speckled noise effect with a smoke-like shape.
UI Path: ||V-Ray Node Editor|| > Shader > Add > Textures V-Ray Speckle
width5%
width35%
Node Input Sockets
width50%
This section describes the input sockets of the node. Some sockets have dedicated parameters, which are further described below, and some sockets are just inputs.
Mapping – Allows a UVW Mapping or a UVW Randomizer node to be connected to determine the mapping of the ramp.
Color1 (input socket) –  Allows a color node to control the lighter color.
Color2 (input socket) – Allows a color node to control the darker
UvwgenAllows a UWV modifier to be attached to determine the UVW placement of the texture.
Color1 –  Controls the lighter color.
Color2 – Controls the darker color.
width5%
width45%
Image Added
Common
width50%
Compatibility With – Allows you to match the result of the texture in Blender to that in either 3ds Max or Maya. If Alpha From is set to  Maya:
3ds Max – The resulting alpha of the texture is the intensity of the texture.
Maya –
The resulting alpha of the texture is the color luminescence.
Alpha From Intensity – Determines how the alpha of the result is calculated:
Bitmap Alphaalpha Alpha The alpha channel is drawn from the texture.
Color intensity/luminance – Alpha is generated from pixel intensity.
Force Opaqueopaque The Alpha channel is fully opaque.
Invert – When enabled, inverts the colors in the final result.
Invert Alpha – Inverts the alpha channel if Invert is also enabled.
Color Mult – Specifies a multiplier for the texture color.
Color Offset – Color corrects the texture by adding the RGB color values specified here to the RGB color values in the texture.
Alpha Mult – Specifies a multiplier for the texture alpha.
Alpha Offset – Specifies an additional offset for the texture alpha.
No UVs Color –  Specifies a default color used for polygons with no valid UVs. In case the map is not tiled, specifies a default color that is used outside the texture square.
width5%
width45%
Image Added
Mapped
width50%
Placement Type – Select how to place the texture.
Whole Texture is Valid – Uses the full valid portion of the texture.
Crop – Allows the user to specify a section of the texture using the parameters below.
Place – Allows the user to specify a section of the texture and how to place it using the parameters below.
U – U coordinate of the texture sector.
V – V coordinate of the texture sector.
W – W coordinate of the texture sector.
H – Specifies the height of the texture sector.
Jitter – Specifies a randomization value for the UV placement.
Tile U/ Tile V – Enable to choose between horizontal or vertical tiling.
UV Noise On – Enables UV noise.
Animate UV Noise – If enabled, the noise is animated. Use the UV noise phase to animate the noise.
UV Noise Amount – Specifies the UV noise amount.
UV Noise Levels – Specifies the UV noise iterations.
UV Noise Size – Specifies the UV noise size.
UV Noise Phase – Specifies the UV noise phase.
width5%
width45%
Image Added
Properties
width50%
UV Noise Phase Specifies the UV noise phase.
Color1 – Controls the lighter color. This channel can also be connected to a texture map.
Color2 – Controls the darker color. This channel can also be connected to a texture map.
Size – Controls the scale of the procedural texture produced.
width5%
width45%
Image Added
