This section describes the input sockets of the node. Some sockets have dedicated parameters, which are further described below, and some sockets are just inputs.
Mapping – Allows aUVW Mapping or aUVW Randomizernode to be connected to determine the mapping of the ramp.
Color 1,2,3, Filter (input socket) – Allows color nodes to be assigned as the colors of the Granite texture.
Cell Size (input socket) – Allows an integer-outputting node to be connected as the Cell Size parameter.
Density (input socket) – Allows an integer-outputting node to be connected as the Density parameter.
Mix Ratio (input socket) – Allows an integer-outputting node to be connected as the Mix Ratio parameter.
Spottiness (input socket) – Allows an integer-outputting node to be connected as the Spottiness parameter.
Randomness (input socket) – Allows an integer-outputting node to be connected as the Randomness parameter.
Threshold (input socket) – Allows an integer-outputting node to be connected as the Threshold parameter.
width
5%
width
45%
width
60%
Image Added
width
40%
Common
width
57%50%
Compatibility With – Allows you to match the result of the texture in Blender to that in either 3ds Max or Maya. If Alpha From is set to Maya:
3ds Max – The resulting alpha of the texture is the intensity of the texture. Maya– The resulting alpha of the texture is the color luminescence.
Alpha From Intensity – Determines how the alpha of the result is calculated:
Bitmap Alpha– The Alpha channel is drawn from the texture. Color intensity/luminance– – Alpha is generated from pixel intensity. Force Opaque– Alpha channel is fully opaque.
Invert – When enabled, inverts the colors in the final result.
Invert Alpha – Inverts the alpha channel if Invert is also enabled.
Color Mult–Corrects the color of the texture by multiplying the the RGB color values in the texture with the RGB color values specified here.
Color Offset–Corrects the texture's color of the texture by adding the RGB color values specified here to the RGB color values of the texture.
Alpha Mult– – A Multiplier for the Alpha value.
Alpha Offset– – Determines the offset value for the Alpha.
No UVs Color–Specifies a default color used for polygons with no valid UVs. In case the map is not tiled, specifies a default color that is used outside the texture square.
width
5%
width
38%45%
Image RemovedImage Added
Mapped
width
57%
50%
UV noise phase – Specifies
Placement Type – Select how to place the texture.
Whole texture is valid Crop Place
U – U coordinate of the texture sector.
V – V coordinate of the texture sector.
W – W coordinate of the texture sector.
H – Specifies the height of the texture sector.
Tile U/ Tile V – Enable to choose between a horizontal or vertical tiling.
UV noise on – Enables the noise.
UV noise amount – Specifies the UV noise amount.
UV noise levels – Specifies the UV noise iterations.
UV noise size – Specifies the UV noise size.
UV noise phase – Specifies the UV noise phase.
Animate UV noise – If enabled, the noise is animated. Use the UV noise phase to animate the noise.
width
5%
width
38%
Image Removed
Properties
width
57%
UV noise phase –
Color 1 – Specifies the first color of the spots.
Color 2 – Specifies the second color of the spots.
Color 3 – Specifies the third color of the spots.
Filler Color – Specifies the color that fills in the area surrounding the spots.
Cell Size – Controls how large or small the cells are.
Density – Controls how closely packed the spots are.
Mix Ratio – Controls the prominence of each color relative to the others.
Spottiness – Controls how circular the spots are. Lower values make the spots more circular, and higher values make them less circular.
Randomness – Varies the distribution of the spots on the granite. Lower values show more spots, higher values also make them more sparse.
Threshold – Controls the transition between the filler color and Color 1, Color 2 and Color 3.
