This page provides information about the UVW Gen Randomizer texture in V-Ray for Blender.
width50%
The V-Ray UVW
Randomizer allows applying random offset, rotation, and scale to textures. To use it, connect the UVW
Randomizer to the
Uvw attribute of a texture node.
width5%
width45%
Image Added
Properties
width50%
Random By FaceConsiders the face IDs of the object when feeding the data (color or texture) to the material.
Random By Render Id Assigns random colors based on RenderIDs.
Random By ParticleAssigns random colors based on ParticleID.
Random By InstanceAssigns random colors based on InstanceID (works for Alembic instances).
Random By Object Objects Id Considers the Object IDs of the object when feeding the data (color or texture) to the material.
Random By Node HandleEach node in Houdini is assigned a unique number (a handle) when it is created. This option generates erates the color index based on that node ID. It is useful because the node handle survives through scene editing - e.g., if you add/remove other objects or rename them, you still get the same colors.
Random By Node Name Generates erates a color index based on the name of the node that the texture is applied to. This allows the color to remain consistent if the object is merged into another scene, or X-Ref'd, etc.
Random By Mesh ElementAssigns random colors based on the element (e.g., teapot lid, etc.) IDs of the object.
Random By Uv Tile Stochastic TilingChanges the mapping based on the UV tile.
Tile Blend – Edge blending between adjacent tiles when Stochastic Tiling is used.
Seed – Changes the randomization pattern.
width5%
width45%
Image Added
Offset Variance
width50%
The Variance controls the position of the map along the U or V axis.
Variance U Range Min/ MaxThe min and max range in which the offset of the U axis is applied.
Variance U StepsSpecifies the number of steps in which the variance interval is achieved.
Variance V Range Min/MaxThe min and max range in which the offset of the V axis is applied.
Variance V StepsSpecifies the number of steps in which the variance interval is achieved.
width5%
width45%
Image Added
Rotation Variance
width50%
Rotation Range Min/Max Variance rotation min/max –  The min and max range in which the rotation parameters are applied.
Variance rotation Rotation stepsSpecifies the number of steps in which the variance interval is achieved. For example, if UV rotation is set from 0 to 360 with a Step of 5, the texture is rotated at an angle that is a multiple of 72 degrees (e.g. 72, 144, 216..)
width5%
width45%
Image Added
Scale Variance
width50%
U Scale Range Min/Max U scale min/max – The min and max range in which the scale parameters are applied to the U axis.
Variance U scale stepsScale Steps – Specifies the number of steps in which the variance interval is achieved on the U axis.
Variance V scale min/maxScale Range Min/Max The min and max range in which the scale parameters are applied to the V axis.
Variance V scale steps Scale Range Steps Specifies the number of steps in which the variance interval is achieved on the U axis.
Variance V scale unlocked Scale Unlocked When enabled, the U and V axes can be scaled separately.Tile BlendEdge blending between adjacent tiles when Random By Uv Tile is used.
width5%
width45%
Image Added
Mapping
width50%
Wrap U/V – Controls how the map is wrapped.
None – It is rendered as is.
Tile – Tiles the bitmap.
Mirror Tile  Tiles the bitmap in a mirror pattern.
Crop U/V – When enabled, crops the map on the respective axis.
Wrap Mode – Specifies how to wrap the map:
On 0.5 Boundaryboundary
On Integer Boundaryboundary
width5%
width45%
Image Added
