width65%
V-Ray Renderer is the main V-Ray component. It builds the scene and initiates the rendering process. Right-click to Start or Stop the render process or to show the V-Ray Frame Buffer window.
Note that if you close or minimize the V-Ray Frame Buffer window while rendering, you can restore it via the Show Frame Buffer option.
width10%
width25%
Image RemovedImage Added
Input Parameters
Engine(Integer)– Switches between CPU, CUDA, and RTX render engines. Make sure to specify the devices to be used by CUDA and RTX engines. You can specify them from V-Ray's GPU Device Selection tool (V-Ray > Tools > GPU Device Selection). Note that the RTX engine can only run on GPU devices with Compute Capability 5.2 or higher.
Mode (Integer) – Switches between Interactive and Production rendering modes.
Sampler (Integer) – Switches between Progressive and Bucket sampling methods.
width60%
Scene(Generic Data)– This is the V-Ray scene output. It can be connected to a V-Ray Exporter component in order to export the scene to a disk or V-Ray Render in Project component to transfer all scene data to Rhino.
UI Text Box
typeinfo
Chaos Cloud is now integrated within V-Ray for Grasshopper. Right-click the V-Ray Render component to find the new option Render on the Cloud action. Note that having a Timeline component connected always exports an animation.
Context Menu
Right-click on the V-Ray Render component to open.
Render – Starts the rendering process.
Render Interactive – Starts Interactive rendering.
Render Animation – Renders animation.
Render on the Cloud – Automatically exports a .vrscene and submits it to Chaos Cloud for rendering. Note that animations are always included when present.
Stop –  Stops the rendering process.
Show Frame Buffer – Shows the V-Ray Frame Buffer.
Use default light – Adds a directional light with default parameter values if no other light exists in the scene.
width10%
width25%
Rhino8_VRay6.2_RenderComponents_Render_ContextMenuImage RemovedImage Added
Right-click on the component to see more options.
