Creates a layer. Multiple layers of the same type can be added.
Folder - Allows grouping multiple layers in folders. This is only available when the Source layer is set to Composite;
Background – Adds a background Vignette – Adds a vignetting effect to the image.
ICC Profile – The ICC correction allows you to apply an ICC profile to the image, so that (for example) it matches the appearance of the image in Adobe PhotoShop.
Filmic Tonemap – Contains different types of mapping curves and gamma corrections. Also allows selection of a color space.
Lookup Table - Allows loading a LUT file for color transformations;
Curves – Adds a Curves color correction layer;
Color Balance - Adds a Color Balance color correction layer;
Hue/Saturation - Adds a Hue/Saturation color correction layer;
White Balance - Adds a White Balance color correction layer;
Render element - Selects a render element from your image that you can use in compositing. This is only available when the Source layer is set to CompositeExposure - Adds an Exposure color correction layer;
Constant - Adds a solid color that can be used to achieve an effect on another layer (for example to multiply by the constant);
Integer mask elementRender element - Selects a render element from your image that you can use in compositing. This is only available when the Source layer is set to Composite;
BackgroundAdds a background color correction layer;
Integer mask – Mask is used with integer render elements like VRayRenderID, VRayObjectID, and VRayMtlID Render Elements.
MultiMatte mask element – Mask is based on the MultiMatte Render Element.
Image alpha maskThe Image Alpha Mask is based on the rendered Alpha channel.
Cryptomatte mask element –  Mask
is based on the VRayCryptyomatte Render Element.
Proportion Guide – Adds a grid proportion guide layer.
Deletes the selected layer(s).
Saves a layer tree preset.
Loads a layer tree preset.
Quick access to custom layer presets. You must set the path to it in the VFB Settings.
Undo various actions related to layers, such as create, delete, reorder, or modify a layer.
Redo various actions related to layers, such as create, delete, reorder, or modify a layer.
