Status
subtletrue
colourBlue
titleV-Ray 7 Beta
This page provides information about the OpenPBR shading model in V-Ray Material in Maya.
width40%
The main difference between the V-Ray material model and OpenPBR is the layers' structure. See the diagram for information on how OpenPBR's layers are calculated.
Fuzz Layer
OpenPBR's topmost layer is Fuzz, which is based on the "Practical Multiple-Scattering Sheen Using Linearly Transformed Cosines"; Tizian Zeltner et all; Siggraph 2022 paper. The Fuzz layer is calculated by itself, unlike in V-Ray Material, where Sheen is coupled with the Diffuse layer. The OpenPBR's Fuzz affects the Coat, Reflection, Refraction, and Diffuse layers, but is not affected by them.
Coat Layer
The Coat layer has an additional parameter, which controls anisotropy.
The Coat parameter simulates a clear, glossy top layer often found on materials like car paint or varnished wood. This layer reflects light, enhancing the visual depth of the material, and adds realism by mimicking physical coatings in the real world.
width5%
width55%
Image Added
Coat Darkening
Coat Darkening is a parameter that controls how the coat layer impacts the appearance of the underlying layers, dielectric or metallic. This effect emulates how a clear coat layer slightly darkens the underlying material due to light absorption and scattering. By adjusting this parameter, you can create slight color changes, adding depth and making renders look more realistic.
Roughness
OpenPBR uses the roughness model to simulate light interaction with surfaces.
Roughness determines how smooth or rough a material's surface appears by controlling the scattering of light reflections. A lower roughness value results in sharper, more mirror-like reflections, while higher roughness values produce blurred, diffuse reflections. This parameter is crucial for simulating various surface finishes, from polished metal to matte materials like rubber or chalk.
Emission
V-Ray Self-Illumination corresponds to OpenPBR Emission, and the emission layer is positioned before the coat layer.
Anchor
tft
tft
The Emission setting allows materials to emit light independently, creating glowing effects. This feature is often used to simulate lights, screens, or any surfaces that need to radiate brightness in a scene.
Thin Film Thickness
In VRayMtl, the thin-film thickness is measured in nanometers (nm), while in OpenPBR, the thickness is measured in micrometers (μm). For instance, a thickness of 0.5 μm in OpenPBR corresponds to 500 nm in VrayMtl. The conversion is handled internally.
Subsurface Scattering (SSS)
In OpenPBR, Subsurface Scattering (SSS) simulates light penetration and scattering beneath a material's surface, commonly seen in materials like skin, wax, or marble. It captures the effect of light entering the surface, scattering within, and exiting at a different location. OpenPBR defines SSS using parameters such as subsurface color and scale, which control the scattering intensity and depth. This ensures a physically accurate representation of translucent materials.
Metalness
Metalness determines whether a material behaves as a metal or a non-metal. Metallic materials (Metalness = 1) reflect light specularly, with the reflection color derived from the base color, and have no diffuse reflection. Non-metallic materials (Metalness = 0) combine diffuse and specular reflections, with the base color defining the diffuse component. This parameter helps achieve realistic material behavior by accurately simulating the optical properties of metals and non-metals.
Refraction
The refraction property of VRayMtl corresponds to the OpenPBR Transmission setting. The Refraction parameter controls the amount of light that passes through a surface, allowing it to simulate transparent or semi-transparent materials such as glass, water, or clear plastics. This parameter affects the visibility of background elements and other objects behind the material, resulting in realistic depth and light interaction.
By adjusting the Transmission setting, you can achieve a range of effects, from frosted glass to fully transparent surfaces.
Thin-Walled
The Thin-Walled setting determines if a material has thickness. When this option is enabled, objects are treated as having no inner volume, making it suitable for items like double-walled glass or thin sheets of plastic. Conversely, if the setting is disabled, the surface behaves like a solid material.
OpenPBR
width5%
width55%
Image Removed
openPBR name (data type)
V-Ray plugin name (data type)
Maya UI name
base_color (color3)diffuse (acolor texture)Basic parametersDiffuse Color
base_weight (float)diffuse (acolor texture)Basic parametersAmount
base_diffuse_roughness (float)roughness (float texture)Basic parametersRoughness Amount
base_metalness (float)metalness (float texture)ReflectionMetalness
specular_color (color3)reflect (acolor texture)ReflectionReflection Color
specular_weight (float)reflect (acolor texture)ReflectionAmount
specular_roughness (float)reflect_glossiness (float texture)ReflectionReflection Roughness
specular_roughness_anisotropy (float)anisotropy (float texture)AnisotropyAnisotropy
specular_ior (float)fresnel_ior (float texture)ReflectionFresnel IOR
transmission_weight (float)refract (acolor texture)RefractionAmount
transmission_color (color3)rfresnelfresnel_ior (float texture)RefractionRefraction Color
transmission_depth (float)(minus)(minus)fog_depth (float)Depth(minus)
transmission_scatter (color3)(minus)(minus)(minus)
transmission_scatter_anisotropy (float)(minus)(minus)(minus)
transmission_dispetion_scale (float)dispersion_on (bool)Refraction advancedDispertionDispersion
transmission_dispetion_abbe_number (float)dispersion (float)Refraction advancedDispertion Dispersion Abbe
subsurface_weight (color3)translucency_amount (float texture)TranslucencySSS Amount
subsurface_color (color3)translucency_color (acolor texture)TranslucencySSS Color
subsurface_radius (float)fog_color (color)TranslucencyScatter Radius
subsurface_radius_scale (color3)fog_mult (float)TranslucencyScale (cm)
subsurface_scatter_anisotropy (float)(minus)(minus)(minus)
coat_color (color3)coat_color (acolor texture)Coat Coat Color
coat_weght (float)coat_amount (float texture)CoatAmount
coat_roughness (float)coat_glossiness (float texture)Coat Coat Roughness
coat_roughness_anisotropy (float)(minus)(minus)(minus)
coat IOR (float)coat_ior (float texture)CoatIOR
coat_darkening (float)(minus)(minus)(minus)
fuzz_color (color3)sheen_color (acolor texture)Sheen Sheen Color
fuzz_weight (float)sheen_amount (float texture)SheenAmount
fuzz_roughness (float)sheen_glossiness (float texture)SheenSheen Roughness
emission_luminance (float)self_illumination (acolor texture)Basic parametersSelf-Illumination
emission_color (color3)self_illumination (acolor texture)Basic parametersSelf-Illumination
thin_film_weight (float)thin_film_on (bool)Thin FilmEnable Thin Film
thin_film_thickness (float) 1thin_film_thickness_min (float) / thin_film_thickness_max (float)Thin FilmMin / Max Thickness (nm)
thin_film_ior (float)thin_film_ior (float texture)Thin FilmIOR
geometry_opacity (float)opacity (float texture)Basic parametersOpacity Map
geometry_thin_walled (boolean)refract_thin_walled (bool)RefractionThin-walled
geomenty_normal (vector3)bump_map (acolor texture)Bump and Normal mappingMap
geometry_tangent (vector3)(minus)(minus)(minus)
geometry_coat_normal (vector3)coat_bump_map (acolor texture)CoatBump Map
geometry_coat_tangent (vector3)(minus)(minus)(minus)
