width5%
width45%
V-Ray menu
width5%
width45%
Render menu
width55%60%
Shows you information about the installed version
MenuDescription
RenderSelects a V-Ray ROP from a dropdown menu and starts rendering.
Render SettingsSelects a V-Ray ROP from a dropdown menu and opens its V-Ray Render Settings.
Show VFBOpens the V-Ray Frame Buffer.
Light ListerOpens the V-Ray Light Lister dialog.
Cosmos Downloader
Opens the V-Ray Cosmos Downloader.
SettingsOpens the Settings submenu.
Object PropertiesOpens the Object Properties submenu.
ImportOpens the Import submenu.
Pack SceneOpens the Report Bug/RFE dialog.
chaos.com
Opens Chaos website.
HelpOpens the Help submenu.
About QTOpens the About QT window.
About V-RayOpens the About V-Ray window.
width5%
width45%35%
Image Removed Image Added
width55%60%
MenuDescription
Global SettingsOpens the V-Ray: Global Settings window.
UIOpens the UI submenu, containing Reset Log Window and Reset Light Lister Window options.
width5%
width45%35%
width55%60%
MenuDescription
CommonOpens the Object Properties tab.
DisplacementOpens the Displacement tab.
HairOpens the Hair tab.
CameraOpens the Camera Properties tab.
Physical CameraOpens the Physical Camera Properties tab.
Remove V-Ray PropertiesRemoves all V-Ray Properties assigned to the selected object.
width5%
width45%35%
width55%60%
Menu
Description
Chaos CosmosOpens Chaos Cosmos Browser.
Material (.vrscene)Imports a material from a .vrscene file.
AUR Cache (.aur)Imports an .aur cache file (a Phoenix simulation cache file).
width5%
width45%35%
width55%60%
MenuDescription
DocumentationOpens the V-Ray for Houdini online documentation.
TutorialsOpens the Tutorials page of the V-Ray for Houdini online documentation.
ForumOpens the V-Ray for Houdini forum.
width5%
width35%
Image Added
width60%
If you open a scene that contains Cosmos assets which are no longer present on the local machine, you can download them from the V-Ray Cosmos Downloader.
width5%
width35%
Image Added
width60%
Contains information about the Qt version used, as well as Qt licensing information.
The About QT window is available when you click V-Ray menu > About QT.
width5%
width35%
Image Added
width60%
The About V-Ray window is available when you click V-Ray menu > About V-Ray.
The windows shows information about the installed V-Ray version. It also provides links to the following:
The Feedback Program Settings button opens the Chaos Telemetry window where you can enable/disable anonymized and personalized telemetry.
width45%
Image Removed
5%
width35%
Image Added
MenuDescription
Create Render NodeCreates a V-Ray Renderer node as well as a V-Ray Renderer IPR node.
Edit Render NodeOpens a list of existing V-Ray Renderer and V-Ray Renderer IPR nodes. When you click on a given node, its ROP parameters are displayed for edition.
