© Taichi Kobayashi
« Previous Version 8 Current »
This page provides information on how V-Ray options are integrated into the Houdini menus.
V-Ray adds a number of commonly used V-Ray components to Houdini's main menu. From these options, you can manage Render, Object, and Displacement properties; import files; and manage VFB and V-Ray IPR.
V-Ray menu
Render menu
MenuDescription
RenderSelects a V-Ray ROP from a dropdown menu and starts rendering.
Render SettingsSelects a V-Ray ROP from a dropdown menu and opens its V-Ray Render Settings.
Show VFBOpens the V-Ray Frame Buffer.
Light ListerOpens the V-Ray Light Lister dialog.
Cosmos Downloader
Opens the V-Ray Cosmos Downloader.
SettingsOpens the Settings submenu.
Object PropertiesOpens the Object Properties submenu.
ImportOpens the Import submenu.
Pack SceneOpens the Report Bug/RFE dialog.
chaos.com
Opens Chaos website.
HelpOpens the Help submenu.
About QTOpens the About QT window.
About V-RayOpens the About V-Ray window.
MenuDescription
Global SettingsOpens the V-Ray: Global Settings window.
UIOpens the UI submenu, containing Reset Log Window and Reset Light Lister Window options.
MenuDescription
CommonOpens the Object Properties tab.
DisplacementOpens the Displacement tab.
HairOpens the Hair tab.
CameraOpens the Camera Properties tab.
Physical CameraOpens the Physical Camera Properties tab.
Remove V-Ray PropertiesRemoves all V-Ray Properties assigned to the selected object.
Menu
Description
Chaos CosmosOpens Chaos Cosmos Browser.
Material (.vrscene)Imports a material from a .vrscene file.
AUR Cache (.aur)Imports an .aur cache file (a Phoenix simulation cache file).
MenuDescription
DocumentationOpens the V-Ray for Houdini online documentation.
TutorialsOpens the Tutorials page of the V-Ray for Houdini online documentation.
ForumOpens the V-Ray for Houdini forum.
If you open a scene that contains Cosmos assets which are no longer present on the local machine, you can download them from the V-Ray Cosmos Downloader.
Contains information about the Qt version used, as well as Qt licensing information.
The About QT window is available when you click V-Ray menu > About QT.
The About V-Ray window is available when you click V-Ray menu > About V-Ray.
The windows shows information about the installed V-Ray version. It also provides links to the following:
The Feedback Program Settings button opens the Chaos Telemetry window where you can enable/disable anonymized and personalized telemetry.
MenuDescription
Create Render NodeCreates a V-Ray Renderer node as well as a V-Ray Renderer IPR node.
Edit Render NodeOpens a list of existing V-Ray Renderer and V-Ray Renderer IPR nodes. When you click on a given node, its ROP parameters are displayed for edition.
