Comment: added channel type
This page provides information about the Toon Specular Render Channel in V-Ray for Blender.
HideElements
cssselector#tocHorizontal, #tocVertical
50%
width
The Toon Specular Render Channel is an image that stores Toon Specular reflection (highlights) information calculated from the Toon Material.
The brighter the area, the more Toon highlight reflection the object exhibits in the render. Toon Specular highlights are colored if the Reflection Color parameter of a material is colored.
The Toon Specular Render Channel is included in the Specular Render Channel. It can be subtracted from the main back-to-beauty composite, graded, and added back in.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Advanced > V-Ray Toon Specular
width
5%
45%
width
Properties
width50%
Enable Deep Output Specifies whether to include this render channel in deep images.
Color Mapping  Applies the color mapping options specified in the Color Mapping rollout of the V-Ray tab in the Render Settings window to this render channel. This option is enabled by default.
Denoise – Enables the render channel's denoising, provided the Denoiser is enabled.
width5%
width45%
Image Added
