Footnotes
With V-Ray 5 for Rhino, the Zip file created via the Pack Project option includes not only the project file and its V-Ray associated assets but also all native Rhino bitmap textures used in the project file.Anchor 1 1
When you use the Pack Project option, a pop-up message appears that asks you whether or not to pack Cosmos asset files with the project.Anchor 2 2
The 'Set Material ID Colors to Black' option is removed from the V-Ray menu, but this workflow is still possible when using the command _vraySetMtlID.Anchor 3 3
