V-Ray includes a menu with easy shortcuts to some of the most commonly used V-Ray components.
The menu consists of the following submenus: Asset Editor, Chaos Cloud Collaboration, Chaos Cosmos, File Path Editor, Frame Buffer, Light Gen, Rendering, Lights, Objects, Tools, Preferences, Pack Project, and Help.
V-Ray Menu
MenuDescription
Asset EditorOpens the V-Ray Asset Editor.
Chaos Cloud CollaborationOpens the Chaos Cloud Collaboration window.
Chaos CosmosOpens the Chaos Cosmos Browser.
File Path EditorOpens the V-Ray File Path Editor.
Frame BufferOpens the V-Ray Frame Buffer.
Light GenOpens the V-Ray Light Gen.
RenderingOpens the Rendering submenu.
LightsOpens the Lights submenu.
Objects
Opens the Objects submenu.
ToolsOpens the Tools submenu.
PreferencesOpens the Preferences submenu..
Pack Project1 2Allows you to create a Zip file that contains the project file and all the associated assets used in the file (textures, environment maps, proxies, linked blocks and their assets, etc).
HelpOpens the Help menu.
Rendering Submenu
This submenu contains shortcuts to general V-Ray components.
Menu Items
Description
Render
Renders the current view with the V-Ray production renderer.
Interactive Render
Starts a V-Ray Interactive Render.
Render on the CloudSubmits the scene to Chaos Cloud.
V-Ray VisionStarts V-Ray Vision. (deprecated feature)
Chaos VantageStarts Chaos Vantage.
Export VRScene
Exports a VRScene for render.
Batch Render
Shows a V-Ray Batch Render panel.
V-Ray Vision is a legacy feature no longer under active development and is planned for removal in the future.
Lights Submenu
This submenu contains shortcuts for creating Lights in V-Ray.
Menu
Description
Rectangle Light
Creates a Rectangle Light, also known as Area Light. Specify three points in the viewport to define the rectangle and create the light.
Sphere Light
Creates a Sphere Light. Click in the viewport to define the sphere and create the light.
IES Light
Creates an IES Light. Click in the viewport to define the cone of light.
Spot Light
Creates a Spot Light. Click in the viewport to define the spotlight's cone of light.
Point Light
Creates a Point Light, also known as an Omni Light. Click in the viewport to place the point light.
Dome Light
Creates a Dome Light. Click in the viewport to place the sphere. Rhino will prompt the user to specify a dome light texture.
Sun Light
Creates a Sun Light. Launches a Sun Angle Calculator, then allows the user to specify the sun position.
Directional Light
Creates a Directional Light. Click in the viewport to define the light direction.
Convert to Mesh Light
Converts the selected mesh into a Mesh Light object.
Release Mesh Light Properties
Removes Mesh Light properties from the selection.
Objects Submenu
This submenu contains shortcuts for creating Geometry objects in V-Ray.
Menu
Description
Infinite Plane
Creates an Infinite Plane.
Export Proxy
Exports a Proxy object.
Import Proxy or VRScene
Imports a Proxy object or a .vrscene file into the scene.
Add Fur to Selection
Creates a Fur Object. Specify an object in the viewport that the fur will be applied to.
Convert to Clipper
Creates a Mesh Clipper plane.
Add Displacement to SelectionAdds Displacement to selection.
Convert to Scatter Host
Converts selected objects to Scatter hosts.
DecalCreates Decal that projects one material on top of another.
Convert to EnmeshCreates an Enmesh surface object.
Tools Submenu
This submenu contains shortcuts for additional Tool functions.
Menu
Description
Camera Focus Tool
Sets camera focus distance based on a point in the model.
Guess Lens Shift
V-Ray will guess the amount of lens shift that has occurred. Note that it is not usable in any default orthogonal view.
Toggle Camera LockLocks camera position and orientation during Interactive Rendering.
Randomize Object IDs
Randomizes the Object IDs for the selected objects.
Convert Rhino Material
Converts Rhino materials to V-Ray materials.
Randomize Material ID Colors 3
Iterates through all V-Ray materials in the project and for each one assigns a randomly generated color to its ID color parameter.
Apply Enscape Settings
Synchronizes Enscape’s environment and illumination - Sunlight, Sky, and Camera exposure settings with V-Ray's.
External
Opens the external submenu.
External Submenu
Menu
Description
GPU Device Selection
Opens the GPU Selection menu.
V-Ray DenoiserOpens the V-Ray denoising tool.
VRMesh ViewerOpens the V-Ray Mesh Viewer.
Preferences Submenu
MenuDescription
Enscape CompatibilityEnables the support for Enscape materials and assets. When disabled, Enscape data in the scene is ignored.
Reset VFB StateResets the V-Ray Frame Buffer settings and position to the defaults.
Help Submenu
This submenu contains shortcuts for additional Help.
Menu
Description
Chaos AcademyOpens the Chaos Academy online learning resources page.
Chaos ForumOpens the Chaos Forum webpage for discussions and support.
Online HelpBrings you to the Chaos Group Online help site.
API DocumentationOpens the V-Ray for Rhino Object Model Reference Guide.
Support RequestSubmits a new support request to the Chaos Support team.
Ideas PortalSuggests and tracks feature ideas for Chaos products.
LicenseOpens the License submenu.
About V-Ray
Opens the About Chaos V-Ray window where you can find information about the installed version. The window also includes links to Chaos website, and information about the V-Ray Asset Editor Session Log, EULA, Chaos Global Privacy Policy and Copyright notices.
License Submenu
MenuDescription
Release V-Ray LicenseReleases the V-Ray license.
Chaos License Server...Opens the Chaos License Server page.
About Chaos V-Ray
The About Chaos V-Ray window is accessible from V-Ray menu > Help > About V-Ray.
The windows shows information about the installed V-Ray version. It also provides links to the following:
Footnotes
  1. With V-Ray 5 for Rhino, the Zip file created via the Pack Project option includes not only the project file and its V-Ray associated assets but also all native Rhino bitmap textures used in the project file.
  2.  When you use the Pack Project option, a pop-up message appears that asks you whether or not to pack Cosmos asset files with the project.
  3.  The 'Set Material ID Colors to Black' option is removed from the V-Ray menu, but this workflow is still possible when using the command _vraySetMtlID.
