This page provides information on the V-Ray Dome Light.
V-Ray Dome Light shines inward at the scene as if from a spherical or hemispherical light source outside the scene extents. This light is frequently used for Image-Based lighting using panoramic HDR images as environments.
UI Paths
||V-Ray Asset Editor|| > Lights (right-click) > Dome Light
||V-Ray Asset Editor|| > Create Asset (left-click) > Lights > Dome Light
||V-Ray Lights Toolbar|| > Dome Light (left-click) > Dome Light at point tool
||V-Ray Lights Toolbar|| > Dome Light (right-click) > Dome Light as sphere tool
Rhino Menus Ribbon
||V-Ray|| > Lights > Dome Light
Options
Example: Background
This example shows how the render changes according to the visibility of the Dome light and the map attached as a Color/Texture.
Example: Shape of Dome Light
The example below shows the difference between the two types of Dome Light - a sphere or a hemisphere. When a sphere is used the projection of the HDRI goes below the horizon, while when a hemisphere is selected, the render is halved in two by the horizon.
Example: Placing objects into HDRIs using finite dome light
- Left-clicking the Dome Light V-Ray toolbar button leads to creating a Dome light at a specified point, and right-clicking – as a spherical dome light. These options are also available in the vrayLightDome command.
- When using V-Ray GPU, the Texture Resolution parameter also affects the background resolution.
