Provides Render type options and access to the V-Ray Frame Buffer.
Quality
Provides a drop down menu with a specific set of presets. The preset settings range from very low quality “Low” to “High+”.
UI Expand | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Resolution
Provides Output and Crop Box resolution size modification options.
The About Chaos V-Ray window displays information about V-Ray versions installed. It also provides links to the following:
Fancy Bullets | ||
The About Chaos V-Ray window is available from the V-Ray for Revit Ribbon > Online Help > About.
V-Ray
Provides access to your license and the Online License Server.
