« Previous Version 18 Next »
This page provides details on the V-Ray for Revit UI and how it is integrated into the Revit interface.
The V-Ray for Revit Ribbon provides access to all of the settings and options that are featured in V-Ray for Revit.
View
Provides a list of Revit 3D views to render.
Render
Provides Render type options and access to the V-Ray Frame Buffer.
Quality
Provides a drop down menu with a specific set of presets. The preset settings range from very low quality “Low” to “High+”.
Quality PresetRender Engine
CPUGPU
Noise LimitMin Subdivs
/CPU only/
Max SubdivsLight Cache
Subdivs
Light Cache
Retrace
Noise LimitMax SubdivsLight Cache SubdivsLight Cache Retrace
Low0.11860020.1166002
Low+0.0811270020.08247002
Medium0.0412080020.04408002
Medium+0.02142100020.028410002
High0.01264150030.0112815003
High+0.0052100200040.00520020004
Resolution
Provides Output and Crop Box resolution size modification options.
Lighting
Provides access to the V-Ray Sun, V-Ray Dome Light, No V-Ray Lights, and Artificial Lights options.
Assets
Provides access to the V-Ray Asset Editor, V-Ray Appearance Manager, and Chaos Cosmos Browser.
Decal
Enables V-Ray Decal placement.
Camera
Provides access to the V-Ray Camera settings.
Provides access to the V-Ray Settings.
Provides access to the online V-Ray for Revit Help documents.
The following options are accessible through the panel:
  • Online Help – Takes you to the V-Ray for Revit home page.
  • Disable V-Ray Releases your V-Ray license. V-Ray for Revit is locked and won't be available for use.
  • About Displays V-Ray version information, Credits and Copyrights, and the End User License Agreement, as shown in the About Chaos V-Ray section.
  • Feedback Provide us feedback at the V-Ray for Revit forum.
  • License Server Leads to your Online License server information webpage.
About Chaos V-Ray
The About Chaos V-Ray window displays information about V-Ray versions installed. It also provides links to the following:
The About Chaos V-Ray window is available from the V-Ray for Revit Ribbon > Online Help > About.
V-Ray
Provides access to your license and the Online License Server.
