You can either use the quick setup buttons in the V-Ray menu (Physical camera only) or manually enable the options in the camera camera Data properties.
Section | |||||||||||||||
UI Text Box | |||||||||||||||||||
TIP When Camera View is enabled in Blender, to switch between several V-Ray cameras, you need to click on their underlying Camera geometry, not the Object.
Camera Attribute Types
Div | ||||||||||||||
