CSS Stylesheet
.wiki-content .confluence-embedded-file-wrapper.confluence-embedded-manual-size {
    vertical-align: text-bottom;
This page offers information about the Snap dialog menu in Chaos Vantage.
The Snap dialog menu provides options to specify snapping intervals for position, rotation, and scale values of the selected object. The dialog menu is accessible with a right-click on the Snap button (Vantage_TopToobar_TransformSnapping.pngImage Removed Image Added ) in the top toolbar.
UI Text Box
colorlight-cyan
iconinfo
typeinfo
Value snapping does not work for multiple axis in Local space.
Snap dialog menu
width65%
Transformation snap
Translate – Enables snapping for translation along the X, Y, and Z axis at the specified scene unit increment.
Rotate – Enables snapping for rotation along the X, Y, and Z axis at the specified degree increment.
Scale – Enables snapping for scaling along the X, Y, and Z axis at the specified increment.
width5%
width30%
width65%
Object snap
Vertex – When enabled, snaps selected object to vertices of other scene mesh objects.
width5%
width30%
