width65%
Enabled – Turns on and off the mesh light.
Color – Changes the color of the mesh light. See the Color example below.
Intensity – Specifies the intensity of the mesh light's brightness. See the Intensity example below.
UI Text Box
colorlight-cyan
iconinfo
When importing Mesh Lights from a .vrscene file, the Intensity parameter may appear as Luminous power, Luminance, Radiant power or Radiance, depending on the unit type specified in the host application.
Invisible – When enabled, makes the light invisible, both to the camera and to reflections. This is useful to prevent bright speckles on glossy surfaces where a ray with low probability hits the extremely bright sphere. See the Invisible example below.
Double-sided – Specifies whether the light illuminates from both sides.
Shadows – When enabled (the default), the light casts shadows. Turn this option off to disable shadow casting for the light. The value moves the shadow toward or away from the shadow-casting object(s). Higher values move the shadow toward the object(s), while lower values move it away. If this value is too extreme, shadows can "leak" through places they shouldn't or "detach" from an object. Other effects from extreme values include Moire patterns, out-of-place dark areas on surfaces, and shadows not appearing at all in the rendering. See the Shadows example below.
Affect diffuse – Determines whether the light affects the diffuse portion of the materials. The value controls the light's contribution to the diffuse portion of the materials. See the Affect Diffuse example below.
Affect specular – Determines whether the light affects the specular portion of the materials. The value controls the light's contribution to specular reflections. See the Affect Specular example below.
Affect reflections – Specifies whether the light source appears in reflections.
Use global mult. - When enabled, uses the Enable Lights value (Render tab > Advanced mode > Lighting rollout) as a multiplier to Intensity value. When disabled, the light is independent from the global multiplier.
Simple portal – When enabled, the Rect light is treated as a portal and only uses colors from the environment map and not from any scene objects behind the portal.
width5%
width30%
Multiexcerpt
MultiExcerptNameMeshLightExamples
Examples
The following examples demonstrate the effect that individual Mesh Light parameters have on the scene. Click on any image to view it at a higher resolution.
width45%
Intensity
This example shows the effect of the Intensity parameter.
width10%
width45%
Color
This example shows the effect of the Color parameter.
width45%
Image slider
Panel
borderStylenone
Image Modified
Intensity = 5
Panel
borderStylenone
Image Modified
Intensity = 10
Panel
borderStylenone
Image Modified
Intensity = 20
Panel
borderStylenone
Image Modified
Intensity = 30
width10%
width45%
Image slider
Panel
borderStylenone
Image Modified
Color is Green
Panel
borderStylenone
Image Modified
Color is Blue
Panel
borderStylenone
Image Modified
Color is Red
Anchor
InvisibleExample
InvisibleExample
width45%
Invisible
This example shows the effect of the Invisible parameter.
width10%
width45%
Shadows
This example shows the effect of the Shadows parameter.
width45%
Before after
afterLabelon
beforeLabeloff
Panel
borderStylenone
Image Modified
Panel
borderStylenone
Image Modified
width10%
width45%
Before after
afterLabelon
beforeLabeloff
Panel
borderStylenone
Image Modified
Panel
borderStylenone
Image Modified
Anchor
AffectSpecEx
AffectSpecEx
width45%
Affect Specular
This example shows the effect of the Affect specular parameter.
width10%
width45%
Affect Diffuse
This example shows the effect of the Affect diffuse parameter.
width45%
Before after
afterLabelon
beforeLabeloff
Panel
borderStylenone
Image Modified
Panel
borderStylenone
Image Modified
width10%
width45%
Before after
afterLabelon
beforeLabeloff
Panel
borderStylenone
Image Modified
Panel
borderStylenone
Image Modified
