width | 65% |
This page provides information about the Sun rollout of Vantage's Environment tab.
The Sun rollout provides properties to configure the sunlight in the scene. In combination with the settings available in the Sky rollout, they define the overall lighting conditions of the scene.
The Sun rollout is located under the Environment tab in the right-hand side panel.
The Sun settings are grouped into basic and advanced settings tabs.
Basic settings tab. | |
Advanced settings tab. |
Basic Settings
width | 30% |
width | 5% |
Altitude/Azimuth
width | 30% |
width | 5% |
Geolocation Mode
width | 65% |
width | 30% |
width | 5% |
Animated Geolocation Mode
width | 65% |
width | 5% |
width | 65% |
Advanced Settings
width | 5% |
Column | ||
Examples
width | 45% |
Examples
Sun Intensity
This example shows the effect of Sun Intensity
width | 10% |
width | 45% |
Sun Size Multiplier
borderStyle | none |
parameter.
width | 45% |
Intensity = 0.05
Intensity = 0.5
Intensity = 1
Anchor |
width | 45% |
Sun Size Multiplier
This example shows the effect of Sun size multiplier parameter.
Sun size multiplier = 1
Sun size multiplier = 5
Sun size multiplier = 10
Anchor |
width | 45% |
Sun Color Mode
This example shows the effect of the Color mode parameter of Vantage Sun
width | 10% |
width | 45% |
Sun Color
width | 45% |
Color mode = Filter
Color mode = Direct
Color mode = Override
Anchor |
width | 45% |
Sun Color
This example shows the effect of the Sun Color parameter.
Color is orange
Color is red
Color is white
Anchor | ||||
Sun Invisible
parameter.
width | 10% |
Invisibility is off
Invisibility is on
Anchor | ||||
Before after | ||||||||||
width | 10% |
Column | |||||||||||||||||
Sun Shadows
This example shows the effect of the Shadows parameter.
width | 45% |
Shadows is off
Shadows is on
width | 45% |
Anchor | ||||
Sun Affect Diffuse
This example shows the effect of the Sun's Affect diffuse parameter.
Affect diffuse is off
Affect diffuse is on
Anchor | ||||
width | 10% |
Sun Affect Specular
This example shows the effect of the Sun's Affect specular parameter.
width | 45% |
Affect specular is off
Affect specular is on
width | 10% |
width | 45% |
afterLabel | on |
beforeLabel | off |
Panel | ||
