The V-Ray UVW Randomizer allows applying random offset, rotation, and scale to textures. To use it, connect the UVW Randomizer to theUvw attribute Mapping input of a texture node.
Panel
borderColor
#0DB5FF
borderStyle
solid
Click CTRL + H to expand all the hidden input ports of V-Ray nodes. Not all V-Ray input ports are exposed, to save space, but if you need a specific port that is not visible, use this shortcut to show all of them.
width
5%
width
45%
width
50%
Rotation Range Min/Max – The min and max range in which the rotation parameters are applied.
Rotation stepsSteps– Specifies the number of steps in which the variance interval is achieved. For example, if UV rotation is set from 0 to 360 with a Step of 5, the texture is rotated at an angle that is a multiple of 72 degrees (e.g. 72, 144, 216..)
width
5%
width
45%
Image RemovedImage Added
Scale Variance
width
50%
U Scale Range Min/Max – The min and max range in which the scale parameters are applied to the U axis.
U Scale Steps – Specifies the number of steps in which the variance interval is achieved on the U axis.
V Scale Range Min/Max – The min and max range in which the scale parameters are applied to the V axis.
V Scale Range Steps Steps – Specifies the number of steps in which the variance interval is achieved on the U axis.
Variance V Scale Unlocked – When enabled, the U and V axes can be scaled separately.
