Timeline bar – Use this bar to set the current frame or the animation range.
width50%
User Account Chaos account | Panels
Use the  Chaos Account button to sign in/out of your user account and access your models and notificationsopen the My account window.
The Notifications icon shows you notifications about Chaos news and updates.
Use the Panels button to show or hide the panels available in Draw mode (Actor library, Clip library, Background library, Template library, Project properties, and Node properties).
width5%
width45%
Image Added
width50%
My account
Manage my Chaos account – Opens the my.chaos portal where you can manage your licenses, assign or revoke licenses to users in your Organization. For more information, see the My Chaos Portal Guide.
Sing out – You can sign out of your account and switch accounts.
Manage Chaos License Server – Opens the License Server interface (localhost:30304).
See Chaos plans & pricing – Opens Chaos website with available purchase options.
width5%
width45%
Image Added
Image Removed
width50%
Project node tree This window shows a hierarchical view of all the areas and actors in your scene and allows for an at-a-glance understanding of the project. From here, you can create, select, and edit all the elements in the animation.
width5%
width45%
