Scatter treats multiple host objects as one with combined surface area (or volume). If you set Scatter to produce 100 instances of a guest object over two host objects, it does not produce 100 for each host. Instead, it produces 100 randomly distributed instances over both host objects' combined surface area (or volume).
Before after | |||||||||||||||||||||||||||
Section | |||||||||||||||||||||||||||
Column | | ||||||||||||||||||||||||||
Column | |||||||||||||||||||||||||||
Column | |
width | 25%
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||
