The Gaussian Splats object can be hidden from the camera, like any other geometry object in the scene, by using the Affect Camera option.
Alignbefore-after
LabelBefore
alignafterLabelcenter
Image_comparison_slider
Off
beforeLabel
On
width
Panel
50%
borderStyle
LabelAfter
none
Off
Image Added
height50%
Panel
borderStylenone
Image Added
Anchor
Refl
Refl
Example: Affect Reflections
The Affect Reflections option controls if the Gaussian splats object is reflected in other objects in the scene.
width50%50%
Alignbefore-after
aligncenter
LabelBefore
afterLabel
On
beforeLabel
Off
LabelAfter
Panel
Off
borderStyle
height
none
Image Added
Panel
borderStylenone
Image Added
Anchor
Refra
Refra
Example: Affect Refractions
The Affect Refractions option makes the Gaussian splats object seen by other objects in the scene that exhibit refractive properties.
50%
Alignbefore-after
alignafterLabelcenterOff
beforeLabelOff
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
LabelBeforeOn
width50%
LabelAfterOff
height
Anchor
shadow
shadow
Example: Affect Shadows
This example shows how the pink flamingo can produce shadows when the Affect Shadows option is enabled, and doesn't block light when it's not.
LabelBefore
Alignbefore-after
Off
beforeLabelOn
width
Panel
50%
borderStyle
LabelAfter
none
Off
Image Added
height50%
Panel
borderStylenone
Image Added
Anchor
Matte
Matte
Example: Affect Matte Surfaces
When the Affect Matte Surfaces option is enabled, the Gaussian splat is considered as background and receives shadows from the casting object.
LabelBefore
Alignbefore-after
Off
beforeLabelOn
width
Panel
50%
borderStyle
LabelAfter
none
Off
Image Added
height
Panel
borderStylenone
Image Added
50%
Anchor
Color
Color
Example: Color
