This page contains information about the V-Ray Cellular Texture.
Page Contents
stylecircle
width50%
The V-Ray Cellular Texture map generates a procedural cellular noise pattern.
width5%
width45%
UI Paths
width33%
||mat Network|| > V-Ray> Texture > V-Ray Celluar
width33%
||shop Network|| >
V-Ray Material > V-Ray> Texture > V-Ray Celluar
width33%
Node
The V-Ray TexCellular node provides inputs for controlling various texture properties. They correspond to parameters in the section below.
Image Added
Type – Specifies which type to use for the Cellular texture. The choices are Dots, Chips, Cells, Chess Cells, or Plasma.
