UI Paths
Section | |||||||||||||||
Node
The BRDFLight node provides inputs for controlling various material properties. Most correspond to parameters in the section below.
Compensate Exposure –Used when rendering with the V-Ray Physical Camera. When enabled, the intensity of the material will be adjusted is adjusted to compensate for the camera exposure.
This example shows using the BRDFLight material with a texture in the Color slot. In order to control the strength of the light we will need to adjust the value of the Color Multiplier.
Fancy Bullets | ||
