UI Paths
width33%
||shop mat Network|| > Material > V-Ray Material node > V-Ray > Material > V-Ray Proxy Material
width33%
 ||mat out Network|| > V-Ray Render Elements node > V-Ray > Material > V-Ray Proxy Material
width33%
The V-Ray V-Ray MtlVRayMesh node provides inputs for connecting shaders to a V-Ray Proxy.
Image Modified
VRayProxy SOP – Use this parameter to point to the V-Ray Proxy in the scene. Once it is selected, the V-Ray MtlVRayMesh node will create creates inputs for every shape or object in the proxy. Shaders can then be connected to them.
