This page provides information on the Particle Map.
Floatingpagetoc
width50%
The Particle Map is a utility node that provides particle-based shading. It does not have any adjustable parameters. It is used in two types of setups:
  • When used as a map in a material assigned to VRayProxy when alembic particles are present in the specified mesh file it returns the color from the .color channel of the particles.
  • When used as a map in a material assigned to VRayMetaball surface, VRayParticleTex returns the color(s) defined by a Particle Flow operator. The VRayMetaball color source option defines which operator will that be (Display, VRayParticleColor or a scripted vector).
width5%
width45%
UI Path
||Material Editor window|| > Material/Map Browser > Maps > V-Ray > VRayParticleTex
