width50%
The Unclamped Color Render Element is a color image that shows the original colors that were clamped. This render element is useful in the compositing process for enhancing extreme colors (very bright or very dark) or for shading the final image with the unclamped colors.
width5%
width45%
UI Expand
titleUI Path:
||Render Setup window|| > Render Elements tab...
||Render Setup window||  > Render Elements  tab  > Add
button  >
 VRayUnclampedColor
width20%
width60%
Image Added
width20%
width60%
Image Removed
VrayVFB – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Deep output – Specifies whether to include this render element in deep images.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
Denoise – Specifies whether to denoise this render element.
Add background
 – When enabled, adds the background to the render element.
width5%
width35%
Image Added
Examples
width5%
width30%
(with add background disabled)
width30%
Beauty Composite Render
width30%
Composite using Unclamped Color,
made warmer
width5%
