width50%
The VRayMtlOSL material can be used to load OSL shader code files (.osl) or OSL object code files (.oso) and render them directly with V-Ray.
width5%
width45%
Image Modified
UI Paths
width33%
||mat Network|| > V-Ray > Material > V-Ray OSL Material
width33%
||out Network|| > V-Ray Render Elements node > V-Ray > Material > V-Ray OSL Material
width33%
width50%
OSL
Source – Specifies whether the OSL shader code is inserted inlline or loaded through a file.
Path to .oso/.osl file
 – Specifies the path to the OSL shader code file.
width5%
width45%
Image Added
References
Fancy Bullets
typecircle
