||Render Setup window|| > V-Ray tab > Color mapping rollout
Default Parameters
width60%
The following parameters are visible from the Color Mapping rollout when set to
the Default
 Render UI Mode.
Type – Sets the type of color transformation. For more information, please see
the Color Mapping Types
 example below.
Linear multiply
 – Simply multiplies the final image colors based on their brightness without applying any changes. The default selection.
Exponential
 – Saturates the colors based on their brightness. This can be useful in preventing burnouts in very bright areas (for example, around light sources). This mode clamps colors so that no value exceeds 255, or 1 in floating point values.
HSV exponential
 – Similar
to Exponential, but preserves the color hue and saturation instead of washing out the color towards white.
Intensity exponential
 – Similar
to Exponential, but preserves the ratio of the RGB color components and only affects the intensity of the colors.
Gamma correction
 – This option is deprecated. Applies a gamma curve to the colors.
Intensity gamma
 – This option is deprecated. Applies a gamma curve to the intensity of the colors instead of each channel (RGB) independently.
Reinhard
 – A blend
between Exponential
 and Linear multiply. The degree to which one method or the other is applied to the image is specified by the
 Burn value parameter.
UI Text Box
typetip
The default settings for color mapping mean that V-Ray renders out the image in linear space (Reinhard color mapping with Burn value 1.0 produces a linear result).
Multiplier – A general multiplier for the colors before they are corrected
when Type
 is set to Gamma correction, Intensity gamma, or Reinhard.
Burn value – Available
when Type
 is set
to Reinhard. If this value is 1.0, the result is the same as
setting Type
 to Linear multiply. If this value is 0.0, the result is the same
as Exponential. Values between 0.0 and 1.0 blend the two types.
Dark multiplier – Specifies the multiplier applied to dark colors
when Type
 is set
to Linear multiply, Exponential, HSV exponential,
or Intensity
 exponential. The default value is 1.0.
Bright multiplier
 – Specifies the multiplier applied to bright colors when Type is set to Linear multiplyExponentialHSV exponential, or Intensity exponential. The default value is 1.0.
Inverse gamma – The inverse of the gamma value
when Type
 is set
to Gamma correction or Intensity gamma. For example, for a gamma value of 2.2, this value is 1/2.2, or 0.4545.
width5%
width35%
Image Added
Anchor
ColorMappingModesExample
As visible in the above images, the Linear multiply mapping method clamps bright colors to white, causing bright parts of the image to appear "burnt out". Both the Exponential and HSV exponential types avoid this problem. While Exponential tends to wash out the colors and desaturate them, HSV exponential preserves the color hue and saturation.
Advanced Parameters
width60%
The following parameters are added to the list of visible settings available from the Color Mapping rollout when set to
the Advanced
 Render UI Mode.
Image Removed
Gamma – Controls the gamma correction for the output image regardless of the color mapping mode. For example, to correct the image for a 2.2-gamma display, set this parameter to 2.2.
Sub-pixel mapping – Controls whether color mapping is applied to the final image pixels or to the individual sub-pixel samples. In older versions of V-Ray, this option was always assumed to be enabled. However it is disabled by default in newer versions as this produces more correct renderings, especially when using
the universal settings
The
 approach.
UI Text Box
typenote
 The subpixel color mapping option is incompatible with the adaptive lights and can lead to blocky artifacts due to the different sampling rate of the light sources in different cells of the light grid.
Clamp output
 –When enabled, colors are clamped after color mapping. In some situations, this may be undesirable. For example, if you wish to antialias HDR parts of the image as well, turn clamping off. The value to the right specifies the level at which color components are clamped if
the Clamp output
 option is enabled.
Affect background
 – When disabled, color mapping does not affect colors belonging to the background.
Mode – Specifies if color mapping and gamma are burned into the final image. This option replaces
the Don't affect colors (adaptation only)
 parameter from previous V-Ray versions.
Color mapping and gamma
 – Both color mapping and gamma are burned into the final image. This corresponds to Don't affect colors (adaptation only) parameter set to disabled in previous V-Ray versions.
None (don't apply anything)
 – Neither color mapping nor gamma are burned into the final image. However, V-Ray proceeds with all its calculations as though color mapping and gamma are applied (e.g. the noise levels will be corrected accordingly). This can be useful, for example, if you know that you will apply some color correction to the image later on, but wish to keep the rendering itself in linear space for compositing purposes. This corresponds to Don't affect colors (adaptation only) parameter set to enabled in previous V-Ray versions.
Color mapping only (no gamma)
 – Only color mapping is burned into the final image and not gamma correction. This is the default option. V-Ray still proceeds to sample the image as though both color mapping and gamma are applied, but only applies the color correction (Linear, Reinhard, etc.) to the final result.
Note:
The Clamp output
 option, when enabled, has an effect regardless of the value of
the Mode option.
width5%
width35%
Image Added
option.
Expert Parameters
width60%
the Expert
 Render UI Mode.
Image Removed
Linear workflow – This option is deprecated and will be removed in future versions of V-Ray. When enabled, V-Ray automatically applies the inverse of the Gamma correction that is set in
the Gamma
 field to
all V-Ray Material (VRayMtl)
 materials in your scene. Note: this option is intended to be used only for quickly converting old scenes which are not set up with proper linear workflow in mind. This option is not a replacement for a proper linear workflow.
width5%
width35%
Image Added
