This page provides details on the settings available for the OSL Material in V-Ray.
Floatingpagetoc
width50%
The VRayMtlOSL material can be used to load OSL shader code files (.osl) or OSL object code files (.oso) and render them directly with V-Ray. The VRayOSLMtl plug-in can be used with shaders that write in closure color output parameters.
width5%
width45%
