width50%
The VRayMtlOSL material can be used to load OSL shader code files (.osl) or OSL object code files (.oso) and render them directly with V-Ray. The VRayOSLMtl plug-in can be used with shaders that write in closure color output parameters.
width5%
width45%
UI Expand
titleUI Path: ||Right-click on the geometry|| > Assign New Material...
width5%
width30%
||Right-click on the geometry|| > Assign New Material... > VRay section > VRay Mtl 2Sided
Image Added
width30%
||V-Ray Shelf|| > Right-click to Create V-Ray Materials button > VRay Mtl 2Sided
Image Added
width30%
||Hypershade|| > Window tab > Create... > VRay section > VRay Mtl 2Sided
Image Added
width5%
width5%
width30%
||Hypershade|| > Create panel > VRay section > VRay Mtl OSL
width30%
||Create Render Node window|| > VRay section > VRay Mtl OSL
width30%
||V-Ray Shelf|| > Right-click Create V-Ray Materials button > VRay Mtl OSL
width5%
