width50%
The VRayScannedMtl material allows the rendering of scanned BRDF material data stored in .vrscan files. These files are produced by Chaos Group's own internal material scanner and accompanying material creator software.
UI Text Box
sizemedium
typenote
The VRayScannedMtl material requires a separate license to work correctly. Without a license, the material will not show its UI and will render with a watermark, otherwise, it should be able to render the sample scenes below.
The scanned material renders the captured appearance of an actual physical material sample, that has been scanned with special scanner hardware. The material goes beyond single-point BRDF capture and can faithfully represent the textured appearance of a large number of real-world surfaces using bidirectional texture function (BTF) approximation.
Because the scanned material simply reproduces the way a physical material responds to light, is has no notion of "diffuse" or "reflection" components, "normal" or "bump" maps.
The .vrscan files tend to be quite large as they need to pack a lot of data (they need to describe the BRDF of the material over its entire surface).
For more details on VRscans, please see the VRscans documentation space for information on downloadable sample scenes and Frequently Asked Questions or visit the VRscans.com website.
width5%
width45%
UI Expand
titleUI Path: ||Right-click on the geometry|| > Assign New Material...
width5%
width30%
||Right-click on the geometry|| > Assign New Material... > VRay section > VRay Scanned Mtl
width30%
||V-Ray Shelf|| > Right-click to Create V-Ray Materials button > VRay Scanned Mtl
Image Modified
width30%
||Hypershade|| > Window tab > Create... > VRay section > VRay Scanned Mtl
width5%
General rollout
