This page contains information about the V-Ray Edges Texture.
Section | |||||||||||||||
UI Paths
Node
Anchor | ||||
Example: Show Hidden Edges parameter
Section | ||||||||||||||||||||||||||||||||
Anchor ConsiderSameObject ConsiderSameObject
Example: Consider Same Object Only parameter
In this example, the cube and the cylinders are separate objects in the scene.
Anchor | ||||
Example: Mode parameter
