General rollout
Section | |||||
Advanced rollout
Section | |||||
Appearance rollout
Section | |||||
Clearcoat rollout
Section |
The clear coat parameters are similar to those found in |
the VRayCarPaintMtl. These parameters are only available if while scanning an object, it is determined that the object possesses the properties of a material with a clear coat.
VRayScannedMtl can make use of some of the Render Elements. Here is a list of those elements:
