width5%
width30%
Rubber Studded Black
width30%
Stucco
width30%
Walnut Semi-Gloss
width5%
Basic Attributes
The Basic rollout provides the attributes used to set the path to
the .mdl
 file that you wish to load into your chosen material, and an Update button needed to refresh the other attributes available, based on the material file used.
width
60%
MDL file
 – Specifies the file path and .mdl
 file loaded.
Chosen
material – If more than one material definition is included in the loaded .mdl
 file, the selected materials will be seen in the rollouts below.
MDL parameters– The Update button refreshes the additional material-specific attributes for the
loaded .mdl
 file.
width5%
width35%
Image Added
width60%
Any additional material-specific attributes (if any) are listed in this rollout. The example below shows parameters for the Coated Flip-flop Paint material
UI Text Box
typeinfo
 MDL
 MDL material attributes that can accept Render Nodes to map color values can now use File textures as input. Note
: While
that while other texture types may also be used, only File textures are guaranteed to work properly.
width5%
width35%
Image Added
coated_flipflop_paint.mdl Parameters
Advanced Attributes
width60%
Max Ray Depth – Specifies the maximum reflection/refraction depth for the shader.
Remap Roughness
 – When enabled (default), determines whether the plugin expects squared values for GGX Roughness settings.
width5%
width35%
Image Added
System Attributes
width
60%
Filename
 file loaded.
width5%
width35%
Image Added
Importing NVIDIA vMaterials
