This page gives some basic details about the Raw Total Lighting Render Element and explains how it is used in compositing.
Section | |||||||||||||||
UI Expand | |||||||||||||||||
||Render Setup window|| > Render Elements tab > Add button > VRayRawTotalLighting
Common Uses
The Raw Total Lighting Render Element is useful for changing the appearance of the entire lighting of the scene after rendering, using a compositing or image editing application. Below are a couple of examples of possible uses. The first two images show the render element itself and the Beauty render put together. In the following examples, a Matte Render Element was used to isolate different parts of the scene, and then the Raw Total Lighting Render Element was brightened and tinted differently to show the range of editing possible.
Underlying Compositing Equation
VRayRawTotalLighting x VRayDiffuseFilter = VRayTotalLighting
VRayRawLighting + VRayRawGlobalIllumination = VRayRawTotalLighting
