Section | ||||||||||||||||||||||
UI Expand | |||||||||||||||||||||||||||
General rollout
Advanced rollout
Appearance rollout
Clearcoat rollout
The clear coat parameters are similar to those found in the VRayCarPaintMtl. These parameters are only available if while scanning an object, it is determined that the object possesses the properties of a material with a clear coat.
VRayScannedMtl can make use of some of the Render Elements. Here is a list of those elements:
