Official Release
Date – Sep. 12, 2017
DownloadBuild 3.60.01
New Features
V-Ray
Fancy Bullets
typecircle
  • Support for Maya 2018
  • Added Cryptomatte Render Element
  • Added support for Maya render sequence
  • Initial support for Instancer in IPR
  • Changing the image resolution while rendering in IPR with the VFB is now possible
  • SamplerInfo Render Element
  • Toon Render Element
  • Support for Maya's Toon shader setup
  • Added an overscan feature in the render settings camera overrides;
  • Support for the Lens squeeze ratio of the Maya camera
  • Support for the float nodes in LookDevKit
  • Support for the exposure parameter of the File node
  • Support for the -percentRes batch render flag
V-Ray GPU CUDA
Fancy Bullets
typecircle
  • Added support for CPU rendering (c++/cpu device type)
  • Added support for NVIDIA NVLink
V-Ray GPU
Fancy Bullets
typecircle
  • GPU production with DR
  • Add support for Full Light Select render element on GPU
  • Ability to set CUDA devices from the Maya UI without restarting Maya
VFB
Fancy Bullets
typecircle
  • Added test resolution button to the VFB
  • Ability to load progressive resumable files in the VFB
VRayLightSelect
Fancy Bullets
typecircle
  • Added Full mode for light select elements and made it the default setting
VRayMDLMtl
Fancy Bullets
typecircle
  • MDL materials support
VRayMtl
Fancy Bullets
typecircle
  • Added clip and stochastic transparency modes to VRayMtl
  • Implemented Oren-Nayar roughness model
Viewport 2.0
Fancy Bullets
typecircle
  • Support environment maps for the reflections of VRay materials
  • VRaySky preview in VP2
Modified Features
V-Ray
Fancy Bullets
typecircle
  • V-Ray size and dimension units now respect the Maya scene units
  • ZDepth is always exported as 32-bit in multichannel EXR files
  • Improved memory usage when there are millions of instances in the scene
  • Faster rendering of proxies and instances when Embree is enabled
  • Added an option for clearing the render mask
  • V-Ray for Maya DR settings will be saved in a single XML file
  • The VRayShelf right click menu for VRayToon can now list all the available VRayToon nodes
  • The VRayShelf right click menu for VRayClipper can now list all the available VRayClipper nodes
  • Added Use V-Ray VFB option to the right click menu in the VFB icon on the shelf
  • Added max tessellation option for hair
  • The specific frames list for animation now allows spaces
  • Tree controls are now hidden when using Embree
  • Increased the default max paths per pixel to 10000 for IPR
  • Ability to specify a render region with relative 0 to 1 values in Maya batch and vrend
  • Changed Light Select type labels
  • Renamed Maya Fluids' Deep Output/Trace Sets option to Render as Geometry
  • Print what Maya version was used to export the vrscene
  • Reduced CPU usage when IPR is paused
  • Better error messages when writing raw EXR files
  • Possibility to use shader names with MtlMulti/GeomStaticMesh
V-Ray GPU
Fancy Bullets
typecircle
  • Improved logging for the progressive sampler
  • Added support for the Projection Wrap parameter
VRayProxy
Fancy Bullets
typecircle
  • Read multiple UV sets from Alembic files exported from the Maya Alembic exporter
VRayLightIES
Fancy Bullets
typecircle
  • Reworked how controls update
VRayMtl
Fancy Bullets
typecircle
  • Changed the default BRDF to GGX
  • Removed Use reflect/refract interpolation options from VRayMtl
VRayMDLMtl
Fancy Bullets
typecircle
  • MDL sample materials now included with the installation
VRayScannedMtl
Fancy Bullets
typecircle
  • Added Material ID attributes to the scannedMtl in Maya
VRayTriplanar
Fancy Bullets
typecircle
  • Mappable scale attribute for the Triplanar texture
VRayStereoscopic
Fancy Bullets
typecircle
  • Deep EXR + Spherical Camera: Fixed wrong Z value for objects behind camera plane
VRayVolumeGrid
Fancy Bullets
typecircle
  • Improved loading time of VRayVolumeGrid caches
ply2vrmesh
Fancy Bullets
typecircle
  • Added -verboseLevel option to ply2vrmesh in order to limit the output
VRayHairSampler
Fancy Bullets
typecircle
  • Option to get the strand length from hair sampler
XGen
Fancy Bullets
typecircle
  • Added V-Ray attributes to XGen Interactive Groomable Splines
Viewport 2.0
Fancy Bullets
typecircle
  • Preview the refraction of the base material in a VRayBlendMtl
  • V-Ray shader previews now work in DirectX
  • Support transparency in the preview for VRayMtlHair3
  • VRayFur shader preview
  • Clamped opacity to 0.1 by default to avoid invisible objects
Bug Fixes
V-Ray
Fancy Bullets
typecircle
  • Fixed render layer token not working with specific setup
  • Fixed UserInteger not working as texture switch in MultiSubTex
  • simplexNoise now supports dynamic distortion
  • Fixed crash when duplicating and moving objects in RT
  • The <Camera> token is now parsed properly for displaying in the file name label
  • Viewport IPR: Fixed banding with low brightness when using SynColor
  • Rendering no longer resets the A and B images from the VFB history
  • Fixed error in mayapy with Maya 2017 no module vray.rendererCallbacks
  • Fixed invalid geometric normal warning flooding script editor and freezing Maya
  • Visibility of objects in Alembic files is no longer ignored by V-Ray proxy objects
  • Fixed renderable curves not rendering when visibility is keyed
  • Fixed wrong alpha-channel at VFB-borders when using texture render mask
  • Fixed object disappearing when Batch Rendering
  • Fixed deleting a V-Ray Proxy instance removing the vrayMeshMtl for proxy objects remaining in the scene
  • Can't render XGen on render layer other than default fixed
  • Fixed Maya scene getting marked as changed when the VFB is opened or loses focus
  • Divide shading subdivs should be hidden when use local subdivs is disabled
  • Fixed vrend command always returning success
  • Fixed VrayFurPreview not updating in Parallel Evaluation Mode
  • Multi-segmented motion blur: Computing particle velocities when possible
  • Fixed in-process IPR crashes with subdivision
  • Resuming a render with GI turned Off no longer triggers a warning for the Adaptive Lights
  • Fixed pixel aspect ratio not taking correct value until render settings window opened
  • Fixed the Material Viewer in Maya 2016 Hypershade not starting the first time
  • Fixed the PLUGINS variable in the installer ignoring the value entered by the user
  • Fixed zDepth render element infinity color when far color is white
  • Fixed crashes when baking UDIM textures in a specific scene
  • Fixed slow export of ramp texture with lots of color handles
  • Fixed black buckets when adding local machine with DR and Resumable rendering
  • Use default color instead of black for missing textures
  • V-Ray hangs the main thread when some of the license servers are offline
  • Fixed some subtle bugs in chunked scene transfer before rendering and between frames
  • Reduced locking while rendering
  • Fixed first atmospheric effect result is added twice if the second effect is aerial perspective with active set to false
  • Fixed increasing progressive sampler memory usage with each resumed frame
  • Fixed wrong progress during loading and saving progressive resumable files
  • Fixed random pixels activated on an empty scene with the progressive sampler
  • Fixed alSurface's SSS produces NaNs
  • Fixed UVTiles at U index larger than 10 rendering gray
  • Fixed primary_visibility flag of the GeomStaticMesh plugin not working
  • Fixed V-Ray not supporting specific IES lights
V-Ray GPU
Fancy Bullets
typecircle
  • Fixed VRayStereoscopic camera not working when rendered with GPU
  • Fixed OpenCL failing to start
  • Fixed GPU (CUDA) not rendering BRDFVRayMtl fog color texture
  • Fixed TexAColorOp in power mode not working as expected
  • Fixed CUDA Error 700 in specific scene
  • Fixed Camera position not updated when using a Camera Map Per Pixel map in a scene with an animated camera
  • Removed the ocldeviceselect dependency to OpenCL.DLL
  • Fixed MtlMulti's mtlid_gen_float with Instancer not working
  • Fixed sphere lights with animated scale crashing when rendered with motion blur
  • Fixed Objects with VRayOverrideMtl and Visible to camera off still rendered in GPU
  • Fixed Blend material not rendering with OpenCL rendering
  • Fixed Crash with multi-gpu setups in specific scene
  • Fixed Glossiness driven by LayeredTex Alpha from Luminance rendering as 0 when the color is pure white
  • GPU did not render correctly V-Ray triplanar map when the texture used UV tiling more than 1
  • Fixed Artifacts with Adaptive lights, VRayLight exclude lists, and matte objects
  • Fixed Wrong alpha channel with VRayLights with Directional parameter above 0.0
  • Fixed Camera lens distortion not working when motion blur is ON
  • Fixed Geometry disappearing with VRayLightMtl and direct illumination
  • Fixed Color opacity option not working by V-Ray GPU mode
  • Fixed OpenCL failing to build and rendering not starting on Linux
  • Fixed Dome light visible in the alpha through matte object with opacity
  • Fixed Textures not rendering if the filename contains the $ symbol
  • Fixed Dome light affecting matte surfaces when rendered with CUDA
  • Fixed Reflection/Refraction not matte when rendered with CUDA
  • Fixed crash with shared VRayEdges textures between materials in specific scene
  • Fixed broken UVTile with missing file
  • Added support for arbitrary clipper exclude list items
  • Improved triangle intersection precision
  • Installer sets CUDA_CACHE_MAXSIZE to at least 256MB
  • Driver 380+ caused some scenes to render bitmaps with wrong uv
  • Fixed zDepth RE infinity color
  • OpenCL rendered black in active shade after a scene change
  • Fixed artifact in the zenith of the sky with VRayAerialPerspective
  • Fixed crash when rendering with on-demand mipmapping
  • Fixed artifacts when using OpenCL with more than one device
  • Fixed crash when exiting Maya/V-Ray STD after CUDA was used on MacOS
  • Fixed wrong screen mapping for textures assigned to the Environment slot
V-Ray IPR
Fancy Bullets
typecircle
  • Fixed IPR refreshing two times on any change
  • Fixed IPR restarting when selecting an object when Hypershade is open in Maya 2016+
V-Ray / VFB
Fancy Bullets
typecircle
  • Deleted images from VFB history are now recycled on Windows
VFB
Fancy Bullets
typecircle
  • Fixed wrong scaling of the channel box for HiDPI displays
  • Fixed stamp button is being replaced upon mouse-over
  • Fixed CC sliders' numeric value edit box not scaling properly on HiDPI screens
VRayProxy
Fancy Bullets
typecircle
  • Fixed no motion blur from Alembic with V-Ray subdivision
  • Fixed all - (hyphen) symbols are replaced by an _ (underscore) when exporting to a VRayProxy
  • Fixed non-ASCII characters are converted to an _ (underscore) when saving proxy file
VRayscene Manager
Fancy Bullets
typecircle
  • Fixed preview type for the vrscene not working
VRayScene
Fancy Bullets
typecircle
  • Fixed UNC path getting prefixed with the vrscene root on Linux
VRayTriplanarTex
Fancy Bullets
typecircle
  • Fixed VRayTriplanarTex texture not following surface deformation even with a reference mesh specified
VRayStereoscopic
Fancy Bullets
typecircle
  • V-Ray now outputs Real Color for stereoscopy only when writing a shademap
VRayRectLight
Fancy Bullets
typecircle
  • Fixed random texture being assigned to the rectangle light file texture
VRayDomeLight
Fancy Bullets
typecircle
  • Fixed lag in Viewport 2.0 when rotating dome light with texture when useTransform is enabled in placeEnvTex
  • Fixed flipped preview in the viewport of a ramp texture in a dome light
VRayFur
Fancy Bullets
typecircle
  • Fixed fur disappearing in IPR on frame change
VRayOSLMtl
Fancy Bullets
typecircle
  • TLS limit is hit with 1000+ OSL nodes
VRayOSLTex
Fancy Bullets
typecircle
  • Fixed OSL not respecting mipmap levels
VRayVolumeGrid
Fancy Bullets
typecircle
  • The "Load nearest if missing" option is now working properly when previewing VRayVolumeGrid
  • The "Loop Overlap" option is now working properly when previewing VRayVolumeGrid
  • Fractional value for the "Play Speed" option is now working properly when previewing VRayVolumeGrid
