The V-Ray Proxy Material is used to assign shaders to the V-Ray Proxy geometry.
UI Paths
||mat Network|| > V-Ray > Material > V-Ray Proxy Material
||out Network|| > V-Ray Render Elements node > V-Ray > Material > V-Ray Proxy Material
Node
The V-Ray MtlVRayMesh node provides inputs for connecting shaders to a V-Ray Proxy.
width5%
width45%
Image Removed
width50%
VRayProxy SOP – Use this parameter to point to the V-Ray Proxy in the scene. Once it is selected, the V-Ray MtlVRayMesh node creates inputs for every shape or object in the proxy. Shaders can then be connected to them.
Force Update – Force reload material information from the V-Ray Proxy SOP.
width5%
width45%
Image Modified
