changes.mady.by.user Gergana Lilkova
Saved on Dec 17, 2019
Saved on Sep 10, 2020
The The V-Ray TexInvert node is a utility used to invert texture colors.
Image Removed
UI path:
||mat Network|| > V-Ray> Texture: Utility > V-Ray Invert
||out Network|| > V-Ray Render Elements node > V-Ray > Texture: Utility > V-Ray Invert
The V-Ray TexInvert node provides inputs that correspond to the parameters in the section below.
Image Removed Image Added
Texture – Specifies the texture that has its colors inverted.
Invert Alpha – When enabled, the texture alpha is inverted as well.
Image Modified
