width50%
Component – Specifies which component to show.
U
V
W
width5%
width45%
Multiexcerpt include
MultiExcerptNameTexture Placement
PageWithExcerptVNFR:ClothBitmap
Fancy Bullets
typecircle
  • UVW texture can be used to display vertex color data from V-Ray for Grasshopper. For this purpose it needs to be slotted as a diffuse texture of a material and set to use UV channel 2. The material then can be used in a "V-Ray Material from File" or "V-Ray Material from Project" Grasshopper component. For more info, see V-Ray Material from File.
