Enable Deep Output – Specifies whether to include this render element in deep images.
Depth from Camera – Specifies whether to use to camera clip boundaries as the minimum and maximum Z-Depth distance. Enabling this option disables the the Depth Black and Depth White parameters.
Depth Black – Objects up to this distance from the camera will render as black.
Depth White – Objects further than this distance from the camera will render as white.
Depth Clamp – Clamps the Z-Depth colors to a linear 0-1 range.
Depth Invert – Inverts the colors of the Z-Depth render element. Objects closest to the camera render as white, while those furthest away are black.
